Test 1 Try to solve the problems first and see if the answer you have chosen is correct. For detailed explanation click on Explain button. 1. Which of these coordinates is NOT a right handed system? c and d a and b Explain
2. Prove that the summation of square of direction cosines is 1. 3. If the cartesian coordinates of point A are (6,6,7), what is the vector connecting point O to point A in the following figure:
4. If A=[2,3,4] and B=[6,4,1], then what is the vector connecting point A to point B 4i + j -3k 4i + j +3k Explain 5. Is the vector connecting point A to point B is the same as the vector connecting point B to point A? No Yes Not sure
6. If vector r is defined by -3i+6j-k, what is the unit vector along r? -i + j - k -0.442i + 0.885 j - 0.147k Explain
