Test 1 Try to solve the problems first and see if the answer you have chosen is correct. For detailed explanation click on Explain button. 1. A block of mass m is resting on an inclined plane. The coefficient of friction between the block and the plane is 0.25. Determine the maximum value of the inclining angle?
14.03 0.25 Explain
2. A ladder of weight 60 Nt leans against a frictionless wall. The other end of the ladder is on a floor where the coefficient of static friction is 0.3. If the bottom of the ladder is located 3 meters from the wall and the length of the ladder is 5 meters, find the magnitude and direction of all forces, other than the weight, acting on the ladder.
3. What is the maximum distance at which the bottom of the ladder in the problem above can be placed away from the wall before the ladder slips?
